1. We are no longer supporting TapaTalk as a mobile app for our sites. The TapaTalk App has many issues with speed on our server as well as security holes that leave us vulnerable to attacks and spammers.
    Dismiss Notice
When do you guys replace your secondary springs?
Discussion in 'Engine & Clutching' started by Redbeard, Mar 9, 2019.
  1. Redbeard
    Redbeard Lifetime Member Lifetime VIP Member VIP Member
    1,728
    IN
    Country:
    Snowmobile:
    2012 Apex, 136 M20, PB80
    2008 Vector, 136 M20, PB80
    2004 RX Warrior
    1995 Vmax 4 800
    1995 Vmax 600 LE
    1995 Ovation 340 LE
    When do you guys determine the appropriate time to replace your secondary springs? Do you have a set mileage you change them, or do you monitor the performance? I have over 9,000 miles on my current spring and I'm noticing a 200-ish drop in RPM and a loss of 10 mph.
    The drive belt is new, the engine and driveline are healthy, and the primary is tip-top...been through all of this.
    I assume a weakened spring would allow the secondary to shift too soon and pull down my revs?
    :sled1:
  2.
  3. Redbeard
    1,728
    IN
    Country:
    Snowmobile:
    2004 RX Warrior
    1995 Vmax 4 800
    1995 Vmax 600 LE
    1995 Ovation 340 LE
    I think I just answered my own question ...
    Team roller secondary:
    Left spring is brand new, right is used. Same spring, but there is 1/4" difference in height between the two. The used spring is shot!
    I don't see any reason a stock Yamaha spring, or other mfg, wouldn't fall into the same category.
    Today's lesson:
    Don't run your clutch springs 9,000 miles, or performance will suffer. :cool:
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
