wantboost
my dealer says can only get them with complete carbs.where are you guys getting these mountain float bowls.better yet anyone make some nice cnc ones
It was an update that yamaha was doing in 2004ish, on Mountain sleds. Might find a set laying around @ a dealership in the west. There was a company that made a different main jet or jet extension or something to fix that problem. Forgot the name, somebody on here will know it thou.
wantboost
i can't find these things any place.how important are they
The only difference is an oring on the botom of the main jet which lightly seals against the float bowl when it is installed back on. They are only used for very steep boondocking to keep fuel to the main jet when at a very steep angle.
rx-hi
I thought they changed the design of the float bowl to keep the fuel from washing away from the main jet also. If you are a mountain rider the update is a must. if trail and flat land not that important. I would check on the parted out sleds in the classified.
rx-hi said:I thought they changed the design of the float bowl to keep the fuel from washing away from the main jet also. If you are a mountain rider the update is a must. if trail and flat land not that important. I would check on the parted out sleds in the classified.
The new design was to add a oring to the bottom of the main jet.
wantboost
i thought it was a deeper bowl to hold more fuel
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Old design on the left and new design on the right.
From the 2004 tech update book. "The float bowl chamber shape and main jet holder are changed to improve fuel delivery during steep hill climbing angles."
wantboost
thanks for the pics,my dealer called yamaha and got a set
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Srxspec said:Old design on the left and new design on the right.
Or hard accleration LOL!
I didnt know they changed the design of the bowls I thought there was just a oring installed. Now I know!
wantboost
hey ted how was your vac?are you back in the shop
rx-hi
Sorry to exclude you and your launches Ted. Your starts have got to be as hard as our cresting!
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
Vacation was a Blast, 12 days of NO PHONES LOL!
Yes I am back and Busy making sure I don't miss any emails or calls.
rx-hi
Tundra has an 04 carb rack for 250 in classified this would give you the update!
