Where does this hose go? Phazer FX
Antewallgren
Sävar
Sweden
Yamaha Phazer FX 07
I've had some stuff apart and I noticed that the hose nr 23 is missing. Where does it lead and connect to? Thanks!
That hose is for the fuel pressure regulator. On this engine it just goes to atmosphere reference so it isn't really needed. I suppose it helps keep snow/moisture from easily entering the regulator and causing rust.
I don't remember it being that long though. Mine were just a short hose with a 90 deg. elbow pointing down. You could just use a short piece of vacuum hose and point it down as long as it's not kinked.
