Where to find 5v on yamaha nytro?
unlited
Age
34
Setermoen
Norway
Nytro MTX 163" 240 Turbo 2010
Nytro MTX 153" 190 Turbo 2013
Nytro MTX 153" Supercharged 240 hp 2012.
can some one told me where to fine 5v on my nytro? Need it to the map sensor / boost sensor, to the powercommander
Thx
Clutch side, should be velcroed to rad fan shroud on top.
I will check it out. Do you have a picture where?
This should help
Yes how to install the pcv its okey, but i need 5v to the map sensor / boost sensor i want to install. Where to find that on the snowmobile?
Do you want to know where the boost sensor goes. I see your from across the pond. The language is coming across a little different. You can install an O2 sensor for the autotune function, but that requires the autotune module. A map you just upload from a laptop. Hope this helps. If not keep asking we will get to bottom of it eventually.
I need to know where to find 5v to e map sensor, the snowmobile has 12v but dynojet say i need 5v to the sensor, is it 5v on the thortel posision sensor? This is that it need to install
Not sure on that one. You must be running a different setup. I'm just running PCV, huricahur map, full Hindle exhaust, air box mod with proper clutching. Not sure how you are setup, normally dynojets are plug and play unless you add the autotune box.
Do you have a supercharged nytro? Hors power? Boost?
Stock motor. No super charger, no Turbo. Just PCV, exhaust, and air box mod.
