Bossrx1
I need to diagnos a code.
Here is what is flashing.
! in the triangle
fuel pump symbol
the entire gas gauge
They all flash together 8 times then pause 8 times then pause.
Thanks for any help.
Bob
! in the triangle
fuel pump symbol
Bob
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
Manual says Fuel level warning indicator
" The fuel level warning indicator indicates a malfunctioning sensor, disconnected coupler, broken lead, or short circuit when detected by the self-diagnosis device of the snowmobile."
Hope this helps....good luck with the problem.
Bossrx1
Thanks for the info, where is the coupler or does it say where to check?
Bob
Bob
SnoWarrior
- Jan 13, 2005
- Long Island, NY
SnoWarrior
- Jan 13, 2005
- Long Island, NY
Bossrx1
Thank you very much for your help.
- 32K
