noob
I looked quite a few pages back here and couldn't find it. seems like someone in alberta had made a plate to bolt on under the tunnel to solve the track hitting the bracket and ripping the track and bracket apart. anybody know who it was?? thanx noob
Darko
CR Racing in Kelowna makes one.
49 buckaroo's, works awesome
tmk50
pics?
noob
Darko said:CR Racing in Kelowna makes one.
just ordered one. sounds like chad has a bunch of stuff in the works. told him to call me when he has the aluminum drop brackets done, steering post and risers and bars too. thanx for info. noob
summitking
apex
alpine motorsports cut down my exaust bracket and put a sheild in as part of warranty.and the put somenew weights in the clutches.what are you changeing the riser to?
Thrusted Vector
I've built a few of these plates and they work just fine.
noob
Thrusted Vector said:I've built a few of these plates and they work just fine.
thanx for telling me.lol still haven't recieved cr racing plate yet, but it's only been 3 days. will post pics when i recieve it. noob
Thrusted Vector
Let me know if you don't get one,I can send you one.
noob
Thrusted Vector said:Let me know if you don't get one,I can send you one.
fo sho, if cr racing one doesnt come this week, i'll call you. noob
vectorboy
I heard Yamaha will have a plate to fit in the tunnel soon.
Mountaintech
Yup they will, thanks to Thrusted Vector!!
hoss
- Dec 19, 2005
There is no plate to cover the tunnel hanging down. Yamaha is having DEALERS trim the tunnel down in the back so it does not hit the track they have even went as far as to fax there trim job to the dealers on how it should be done. On all the sleds that I have trimmed which is about 15 the rubbing is gone and no more track wear.
Thrusted Vector
Ya,you probably don't need it,but the skid plate just cleans things up.
slymax
hoss said:There is no plate to cover the tunnel hanging down. Yamaha is having DEALERS trim the tunnel down in the back so it does not hit the track they have even went as far as to fax there trim job to the dealers on how it should be done. On all the sleds that I have trimmed which is about 15 the rubbing is gone and no more track wear.
Where do you get this info? i work at a dealership and that is not what is happening. In fact, if you cut the bracket you will have nowhere to bolt the plate to. I wouldn't cut it right now.
vectorboy
Plate
Here is a picture of the skidplate i have been using since new. I will keep it until Yammy comes up with its fix. It has been flawless so far.
[/img]
- 32K
