BOONDOCKERDB
- Oct 29, 2010
2000 MILES SO FAR NO PROBLEMS YET..
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Just went over 2000 kms. I bought it new in November 2010!
Nothing up!
Nothing up!
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
4500 kms boosted 15 psi no problems
kamakazie
5000 Miles so far one Engine rebuild covered by YES. Sled was on it's left hand side and oil leaked into the engine. Not good. Can you say check valve!!! Come on Yamaha! Other than that it has been a great sled!!!
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
2500 miles two belts
canuk77
I got 5000 miles with no problems...
rrxx-1
4000 miles on mine, one subframe, balljoints, one belt
5000 miles on my brothers, balljoints, one belt
Both sleds are going to get tore down this summer, new balljoints, bushings, and bearings.
Old Thumper
I guess I win. (so far)
arteeex
8027, but it was a low mile season.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
5000 miles on mine and engine runs great.
So far:
Lower ball joints replaced under warranty (1500 miles)
Bent 08 subframe replaced with 09 frame under warranty (1500 miles)
Tunnel heat exchanger added to the inadequate stock cooling system
Exhaust donuts (3000miles)
1 hyfax replacement (3500 miles)
A-arm bushings replaced with Ulmer's (3500 miles)
Bent 09 subframe replaced with updated 2010 frame (reinforcement gussets added)
Before next season:
Upper and lower ball joints
Outer tie rod ends
Spark plugs
Belt
So far:
Before next season:
Outer tie rod ends
Spark plugs
Belt
Old Thumper
Old Thumper said:7104
I knew there must be higher miles out there...
Replaced lower ball joints
Made bronze A arm bushings
Did the upper ball jt mod
Added Yamaha wet left foot fix
Replaced sliders twice
Replaced carbides twice (Bergstrom Triple pts)
Changed exhaust doughnuts
Replaced belt after 5200 mi
Added a temp gauge
Added a manual fan bypass switch
Added Slidekicks scratchers
I also fried a starter motor, but that was my fault not Yamaha's (power supply for temp gauge)
No other problems
stopdropanroll
6656. Minor issues.
larrypolaris
3230 miles.
One subframe.
One belt.
Two sets of slides
Three sets of carbides(man do Pilot Skis eat carbides on marginal snow)
215 gal of gas
One oil change
A whole lot of fun
One subframe.
One belt.
Two sets of slides
215 gal of gas
One oil change
A whole lot of fun
