rtx moose
- Jul 31, 2014
- WATERTOWN,MN
I NOTICED POLARIS NO LONGER IS CHAIN DRIVEN,,A VERY VERY SIMPLE WEIGHT SAVING CHANGE THAT JUST BLOWS MY MIND WHY DID NOBODY THINK OF THIS YEARS AGO?YAMAHA WOULD JUST HAVE TOO FIGURE OUT THE REVERSE SETUP...
sideshowBob
Nope...Crazy Mountain Extreme had this system on their mountain sleds in the 90s...Polaris just copied it.
http://www.crazymtn.com/sifiso/pages/cmxds.html
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Just like with a-arm front suspensions they probably just were waiting for patents to run out.
Hmmmm. Where would you put the 4stroke reverse?Nope...Crazy Mountain Extreme had this system on their mountain sleds in the 90s...Polaris just copied it.
smokingcrater
Not so sure a belt is better... A properly maintained chain will last a LONG time! Look at timing chains in cars. Timing belts generally are 60k to 105k mileage replacement. There is no replacement interval on timing chains, they last more or less the life of the engine.
toyota4runner
The belt life on a timing belt style drive will far exceed the life of alot of other components on the sled. Not only that but they're simple to change. Weight savings alone and one less stinky fluid is a nice bonus too.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
There is a kit to convert your Yami to a belt drive or at least there was in about 2000 or so. Making a belt drive with a reverse without making it as heavy as a chain drive and still keeping it inside the shroud! That would be quite a job. Would need two belts or like our reverse now or a ton of gears and there goes your weight savings and you replaced it with a bulkier system.
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
srx700lt
The Phazer doesn't have the revers in the chaincase, it's located between the chaincase and the secondary clutch.
cacsrx1
Polaris switched their Pro RMK with the 3" track BACK to a chain drive for 2016.
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
Should be possible to make a direct injected, electronic valve, 4S run backwards also. Think of the weight savings with no cam shaft & no chaincase.
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Polaris has had all sorts of issues with the belt drive from long breakin to short life.
I'll take my chances with the current design.
Grimm
Only a few models of Polaris have belt drive. Most of them still have gears and chain. If belt drive was the bomb, then all their sleds would have it.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
You betcha......but what would the sled MSRP out at?
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
I'm not sure if I'm ready for that level of complexity and or the cost. Love the concept though.
- 10K
