There have been a few exhaust fires that can be attributed to carb coolant shutoffs, so I'd advise against it. Even at above freezing temperatures, with the coolant shut off, under vacuum, the air flowing through the carbs can drop below freezing and cause the carbs to freeze.
As for the sYnc(hronization), use at LEAST two vacuum gauges, at idle, connect them to the fittings at the top of the carbs, adjust the screws between the carbs until each pair of carbs creates the same reading.
