almond1000
- Jan 20, 2008
- North Fond du lac, Wi.
- 2017 sidewinder 2011 vector gt 2010 fx nytro 2009 vector gt
Does anyone know if an 07 phazer primary clutch fit an 08 fx nytro? I know weights and spring is different but wonder if the taper and diameter are the same. My nytro primary has some cracks and ran across a nice low mile phazer primary really reasonable
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
Not sure if phazer clutch is same as nytro clutch but are you sure your clutch is cracked or is it just casting marks?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Yes it will fit. Only difference is no set screws on the weight pins on the pz clutch.
almond1000
- Jan 20, 2008
Yes, it is cracked, i was a die caster for 20 years, i know a casting line from a crack believe me. i did find a decent clutch i am going to put on, i was also going to do the 14.5 rollers and y-p-y spring. I found the roller part number but i see 2 different y-p-y springs, looks like a long and a short, does anyone know which to use?
livewire_101proof
You will want the spring for long cover, as long as u use the outer cover from your nytro clutch, I am pretty sure the Phazer had a short cover though, so if u use the cover coming with the Phazer clutch u would need the short spring. If nobody else knows for sure I can check for you in the next couple days as I have a Phazer and a nytro.
The smaller rollers are easy enough to find used also as that came in slot of the 2 stroke vipers, probably some other models also
almond1000
- Jan 20, 2008
Thanks, ill get the longer spring, i ended up finding a clutch off of nytro so im just planning on the 14.5 rollers and the y-p-y spring
