Hi Firebird, we have used 22/38 to 26/38 with the stk chain on ER models, not 100% sure on none ER's but I would think you can go up or down a couple of teeth on the top gear with no problems.firebird1158 said:Hey, I'm going to put a 23 tooth top gear on my RX1 mountian to give me 23/40 ratio. Will I need to change the chain with this setup?? What length chain is on the Mountain?? 68 or 70?
also can you add reverse with this setup??
