Wind Deflector Installation - Help!
I just installed the tall sheild and deflectors on My wifes Nytro this morning. It went very easy and as far as the Dzus fasteners go the stock ones worked fine. I didn't use the plastic washers that came with the kit. All I did was remove the metal retainer that holds the Dzus fastener and reinstall it with the deflector sheild in between it and reinstalled the metal retaining clip to hold the Dzus fastener to the shroud and deflector. Then I hooked the Dzus fastener into the sled and noticed it was a little tight so I just squeezed the clip the Dzus fastener hooks to with pliers and they work great. You don't have to squeeze the clip very much at all just a little bit. You want the Dzus fastener to hook up tight not loose so be carefull not to squeeze the clip much its not neccessary.
BTW the tall sheild, side deflectors and mirrors look awesome on her sled. I think with these extras her sled will be warmer to ride than My apex.
I just installed my wind deflectors!! Very easy to tweak the Dzus fastener!! It sounded a lot harder than it actually is. Once you see it.... it's a piece a cake!!! Thanks fellas!! :4STroke: :Rockon:
:worth:
some pics:
