coolio
- Feb 23, 2007
I just helped my buddy service his winder and omg wasn't that fun. Who decided to put the oil tank drain there?? What a moron! The last thing we have to do is chaincase oil and this procedure looks ridiculous. Why on earth is there no drain plug?? Do we really have to tear the sled half apart and split the case just to drain the oil? Is there an easier way? And people thought an Apex oil change was a pain! I'm sticking with my Apex for quite awhile after today.
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Yup totally stupid .glad I only do my viper once a year. Helped my buddy do his cat yesterday and he was in shock as well .lol
- Nov 29, 2009
- sabattus, maine
Definitely wasn't well thought out for the yearly maintenance, but making the right side belly pan removable with rivnuts makes it a lot easier. There's a few posts around here showing it.
- Nov 29, 2009
- sabattus, maine
Here's a recent one
https://ty4stroke.com/threads/sidewinder-oil-drain-plug.154722/
Certainly should have been much better design. However, I loosen most of the bottom chaincase bolts a few turns, then carefully use a screwdriver as a wedge to hold the cover open slightly, letting the oil drain out. I'd like to see them make that bottom cover removable from the factory instead of riveted on.I just helped my buddy service his winder and omg wasn't that fun. Who decided to put the oil tank drain there?? What a moron! The last thing we have to do is chaincase oil and this procedure looks ridiculous. Why on earth is there no drain plug?? Do we really have to tear the sled half apart and split the case just to drain the oil? Is there an easier way? And people thought an Apex oil change was a pain! I'm sticking with my Apex for quite awhile after today.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
It's not the best set up but it's not bad once you do it a few times...lol
Good reason to inspect the chain case
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I find it’s not that big of a deal. When doing it you really get to do an inspection. I would recommend with the high hp tunes especially. It’s only nuts and bolts.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
If you have some time and want to see alot of pics...LOL
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-20#post-1406934
Dan
Dan
race24x
Why cant I use my Seadoo oil evacuator and suck all of the oil out of the oil tank?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
You wont get all the oil out of engine. If you look at my oil change posts in my build thread, you will see how I was able to get out ALOT more old oil when I do my changes.Why cant I use my Seadoo oil evacuator and suck all of the oil out of the oil tank?
Dan
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Oil tank is full of baffles, you'd never get a hose to the bottom of it.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Forgot about that Mike....sucker would not get any oil out with all the baffles ect. Good call.
34pontiac
He's right. I tried for a half hour once not knowing about the bafflesOil tank is full of baffles, you'd never get a hose to the bottom of it.
Gave up.
Same with chain case couldn't get hose to bottom with everything in the way. Open case now and look around in there.
Fast
- Sep 25, 2018
I believe he's talking about the chain case since the oil tank has a drain,so if we remove the reverse actuator can we use a suction hose to drain the tank?You wont get all the oil out of engine. If you look at my oil change posts in my build thread, you will see how I was able to get out ALOT more old oil when I do my changes.
Dan
34pontiac
Tried that.I believe he's talking about the chain case since the oil tank has a drain,so if we remove the reverse actuator can we use a suction hose to drain the tank?
Gears are in the way, but kept on trying and finally only got just a little out. Could not get hose all the way in there.
And I tried for a long time.
