snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Got the sled last fall and my helmet was freezing up and so was my face, witch one do you guys recommend?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
The stock XTX shield has been one of my favorites so far. I have added handguards only for the purpose of the little mirrors in them. I wear a snowcross helmet as well. But I do use a Klim Arctic balaclava. We don't ride below -20f usually. That's my mental limit if not physical.
So I will be the first to stick up with the stocker over anything larger or smaller.
i run the stocker on both my sleds as well but i am investing in the lower panel to windsheild defelctors after a few -40 rides. just need another set for my sled as one guy on ebay will not ship to canada. have a set for hers.
- Jun 28, 2004
- Clinton, Wi.
Just replaced mine with.... another stocker. 14,000 ish miles and all but a couple hundrevwith +5" riser. Are you sure yours is stock? Just trying to confirm. If you bought it used PO may have changed it out.
snobill
- Nov 4, 2012
- 2012 apex xtx
snobill
- Nov 4, 2012
- 2012 apex xtx
Not sure?
that looks like the stock one in the pic just from where the bars are in relation height wise. i know as soon as you raise the bars, you need handgaurds to cut the wind as both my apex are +3 and +4 risers.
snobill
- Nov 4, 2012
- 2012 apex xtx
Have the hand guards, hands were good but my face and helmet was frosting up . I had to stop a few times because I think frost bite was starting.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
It looks like an aftermarket seat when I was on the stock seat the stock windshield worked perfect the convex in the center throws the air up and over you when I went to the wrp seat +3 inches the stock windy threw the wind right up my helmet under my chin. I had just been dealing with it but was going to get the extra tall with the support brackets for it but I decided to fix it buy buying a sidewinder instead and now it is my sons sled so he can figure it out from here.
