Yikes you have a lot of reading to do! Make sure you fully understand whats happening in there before making big changes.
Intake air where is the sensor at before or after the intercooler? I don't monitor this on mine so not sure what a good reading is
AF ratio should be around 13-14 idling, and cruising with no boost, 11.2-11.8 under wide open throttle, anything 10 is to rich and anything over 14 is to lean
There is a lot on a turbo sled. Mine is usually the chain tension needs to be set 1-2 times per year pending miles maybe more, the chain will stretch so much it needs to be replaced every other again pending miles. Check the oil and coolant more freq, check the drive shaft and jackshaft bearings on the clutch side yearly and grease them in the sled by pulling off the dust cap with a pick. Track tension should also be monitored as they stretch quite a bit. Driveshaft will last 5K-8K miles after that your risking it (assuming apex sled here?)
Turbos will run 1500-1800 degrees, heat control is everything.
