rcolsen
I have less than 500 miles on 07 FX and it will not go into reverse. Is there a quick fix I can try beore loading it up and haulling it 50+ miles to the nearest dealer for warrentty work?
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
jump up and down on it - works for my fx
mlloyd
Rock the sled back and forth slightly to easy the engagement. Especially when cold
OST
I have to give mine a little tug forward or reverse to get it to work.
A lot of times I have to shut down and restart the engine before reverse will work.
What is your idling rpm?
If it is too high it will not shift into reverse.
rcolsen
I have tried all of that but still nothing - the light just blinks. Thanks
AA.reidlandskp
- Dec 12, 2006
When you get a few more mls on the belt deflection will be more and it will go in with alittle rock of the sled
xc_phazer137
You need to bring it to your dealer and get the reverse update done on it. I think they change the servo motor. I had a problem with mine brought it in and they updated it and now it works awsome!
80h4thephaze
hit the gas a lil bit.
- 25K
- 10K
