ArcticRider
- Nov 19, 2018
- Above the Arctic Circle, Alaska
- 2016 Yamaha Viper STX-DX 146
2021 Vk 540
I live in the Arctic and i currently own a 16’ viper, which barely starts at 0 degrees. Is there a yamaha that will start at cold temps say -30f. I will b using this machine to haul a ton of wood and 50 gallon drums of fuel. Also, need it for hunting moose and caribou. Im hesitant to buy another yamaha but i love my viper when it starts. Thoughts? Im looking at the viking 540 or the pro? But im open to any and all suggestions.
go with the vk540.
the pro is the same engine as the viper but with yamaha tuning in the ecu. needs a block heater after -30 c area unless you put a sled start system on it to keep the coolant above a certain temp. yellowknife said he could get his nitro going without plugging it in around -32 c.
the vk 540 will start at -40 c no problem as long as you pull it over by hand until it is freed up. e start will start it but you have to watch for flooding the engine. ran mine at that temp a few times and my uncles II and III a whole bunch. uncles II is still floating around and i know that thing had over 30000km on it without a engine rebuild on cheaper sled oil when my aunt sold it.
ArcticRider
- Nov 19, 2018
2021 Vk 540
go with the vk540.
Would you say its pretty powerful for towing?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
The VK has a two speed gear box, so you can select low range for towing your heavy loads.
HighSpeedLowDrag
A 1995 vmax-4 st beats everything except a 2010 apex for throttle response, oil consumption, and backing up.
ArcticRider
- Nov 19, 2018
2021 Vk 540
Would any of u suggest adding a primer or some sort of plug in heater?
vk 540 are plenty strong. usually tow the 8' sleigh full of wood in high range. only time i use low range is when i am pulling 30-40' logs out of the bush onto the lake back to camp. prior to his death my uncle would load the same sleigh up with all his trapping and fishing gear and break all the trails into lakes with the sleigh on with very few issues. guys still use them to pull trail groomers in low range, almost did the pre season on a clubs vk last season.
vk pro, add the coolant heater. better to have and not need than need and not have.
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
1976 SRX 440 #554
What? lol
YukonMP
- Dec 25, 2014
- Yukon Territory
As hard as it is for me to say this if cold starts in the bush are a must then I'd say go with a VK540. It will start and will do the job otherwise. That said the VK Pro is an absolute beast for pulling but that doesn't do you any good if you can't get it going. Because of your location I would consider the relative merit of your dealer/dealer network. I know some of the Alaska guys have had good experiences with Yukon Yamaha(Whitehorse) when they couldn't get what they needed out of Anchorage. I also think that this forum is great and all the guys here are helpful and responsive.
ArcticRider
- Nov 19, 2018
2021 Vk 540
After calling 6 places i finally found a vk540 in fairbanks. I did find one vk pro, which does seem awesome but i hesitate because of the cold starting issues with my viper.As hard as it is for me to say this if cold starts in the bush are a must then I'd say go with a VK540. It will start and will do the job otherwise. That said the VK Pro is an absolute beast for pulling but that doesn't do you any good if you can't get it going. Because of your location I would consider the relative merit of your dealer/dealer network. I know some of the Alaska guys have had good experiences with Yukon Yamaha(Whitehorse) when they couldn't get what they needed out of Anchorage. I also think that this forum is great and all the guys here are helpful and responsive.
like i said above, the viepr ecu and the vk ecu are totally different. the vk ecu is like the nitro and vector ecu for starting.
ArcticRider
- Nov 19, 2018
2021 Vk 540
Ok i see. If i only had a heated garage this wouldn't be an issue, but hey we cant have it all.like i said above, the viepr ecu and the vk ecu are totally different. the vk ecu is like the nitro and vector ecu for starting.
Does your vk pro start well in the cold then?
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
If you got electricity you can get a blockheater like this.
https://laitis.se/kontaktvarmare-414813.html
Or hoseheater.
https://laitis.se/slangvarmare-462.html
Or hoseheater.
lol dude, my vk is the og vk. 1988 vk540 is what i run atm. does all i need and the only time it is in the garage is usually when i pre season it.
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
At minus 30 the vk 540 will need some persuading with both the e start and pull cord at the same time, seen numerous times where that was the only way it would turn over, where as my 06 pro would start no problem , but it depends on the sled and condition of the battery, but when comes to the towing capacity the 540 doesn't even come close ! with that said the new vk is no slouch, it idles better, improved fuel economy and better in deep snow . haven't had much experience with the vk pro 2 , but have lots with the carb version and never had any issues starting in cold weather (the coldest being minus 30) but they were well tuned ie: sync and cleaned carbs and everything adjusted to spec! good luck with the decision! cheers!
- 17K
- 38K
