HABS 1
- Oct 22, 2015
- corunna,ontario
oil level is an inch high , coolent bottle is mt, took cap off its fill their, oil level line looks milky...wtf ? 1,300 mi on a 21 , might of got warm once but warm enuff to fk a head? head gasket of cylinder? lookin for some input, theres a problem wondering what the weakest link is? if it as easy as a heas gasket?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Some of these 998's had cracked heads right from the factory or shortly after in stock configuration. Coolant would go down and oil level up and become milky. Sounds like the case here. It's happened with more than a few.
HABS 1
- Oct 22, 2015
- corunna,ontario
where abouts woukd they crack? could i see it by pressurizing coolent with valve cover off ?Some of these 998's had cracked heads right from the factory or shortly after in stock configuration. Coolant would go down and oil level up and become milky. Sounds like the case here. It's happened with more than a few.
The heads tend to crack around the casting plugs visible under the valve cover. The plugs look like big pipe plugs and the cracks are hard to detect but around these. I think it was Turboflash that posted a picture of the cracks a few years ago?
HABS 1
- Oct 22, 2015
- corunna,ontario
thanks fellas il have to pull the cover n see whats going on... i shoukd note this sled has never did this befor, everytime i ride it it gets put back in a heated shop and panels pulled, i check coolent,oil and for oil tank leaks every time! this just happened yesterday,running it pretty hard for an hr, just swapped my clutching over to tp,sled is bang on now , i thoght finally im done dialing and messin with this unit after 5 yrs lol.... now this...... any tips tricks speacal tools, timing, advice would be appreciated,if it turns out to be a head get used complete? or bare yamaha n seap valves? wich brand of head gasket everyone using and im assuming arp stud kit
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Oil cooler on front of engine is another possibility.
When you say it may have got warm once, do you mean it overheated without coolant in it?
Also, is it tuned?
Also, is it tuned?
HABS 1
- Oct 22, 2015
- corunna,ontario
its tuned,max 17 td, got warm last fall at a grass drag event in sept, warm as it my temp light came on, only time its ever come on, shut it down for the night,put couple hindred miles on it since then in snow, no problems, ran fine last night night, pulled it in shop pulled panels like i allways do, had a beer n sat down, looked over thoght bottle looks low... was mt oil up an inch with a tad of milk in the tubeWhen you say it may have got warm once, do you mean it overheated without coolant in it?
Also, is it tuned?
HABS 1
- Oct 22, 2015
- corunna,ontario
i was wondering about an oil cooler, are these known for em? im assuming to test it, pull it off n air it?Oil cooler on front of engine is another possibility.
HABS 1
- Oct 22, 2015
- corunna,ontario
would anyone know what adapter for wich car or a number for an adapter to fit a sw to hook up to my pressure tester? it seems i dont have one that small in my kit
Turboflash
- Mar 18, 2019
- Southern MN
HABS - PM me. My '17 had a cracked head from factory. I can show all kinds of pictures and what to look for. It's a factory assy problem.thanks fellas il have to pull the cover n see whats going on... i shoukd note this sled has never did this befor, everytime i ride it it gets put back in a heated shop and panels pulled, i check coolent,oil and for oil tank leaks every time! this just happened yesterday,running it pretty hard for an hr, just swapped my clutching over to tp,sled is bang on now , i thoght finally im done dialing and messin with this unit after 5 yrs lol.... now this...... any tips tricks speacal tools, timing, advice would be appreciated,if it turns out to be a head get used complete? or bare yamaha n seap valves? wich brand of head gasket everyone using and im assuming arp stud kit
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I’ve had a few cracked heads around the casting plug . Worst one was we ordered a new one to replace the bad one and it was cracked too.
Turboflash
- Mar 18, 2019
- Southern MN
OMG! First time I've heard that!I’ve had a few cracked heads around the casting plug . Worst one was we ordered a new one to replace the bad one and it was cracked too.
HABS 1
- Oct 22, 2015
- corunna,ontario
thats not good! my first step is finding the correct adapter to verify the leak, once verified, a new possibility cracked casting from ysmaha? or just get a used complete head? are their torque specs on thise plugs? mesning remove em ,reseal em and properly torque em in used or new?I’ve had a few cracked heads around the casting plug . Worst one was we ordered a new one to replace the bad one and it was cracked too.
