BrandonL
- Feb 7, 2021
- Comfort cove, Newfoundland
- 2020 Yamaha VK Professional II EPS
2008 Yamaha Bravo LT
Hey everyone I had some time off work this week so i took my 2020 vk pro out of storage, as moving her from storage to my garage to do my maintenance, oil change, chain lube, etc, as i was doing so she threw me a code 84 witch in the manual says a problem with the T.O.R.S ive tried everything witch is leading me to wonder if the plugs are bad would it affect T.O.R.S?
not usually. sounds like your throttle cable might be too tight though.
John B
- Oct 4, 2016
- Watertown, MN
- 2007 RS Viking Professional
I had the throttle cable pop out of the housing/recess at the lever once, which basically tightened the cable slightly. I didn't notice it and mine threw the 84 code. As soon as I popped it back, in it went away...
On my 07 there is a way to bypass TORS if you think it is faulty (it is in the service manual), not sure about the 2020's though.
