juniorXTX
I am aware that there are threads here saying that this track works without issue on the xtx, that's not what this thread is about..
For those of you who have added the larger lug track.. and I would imagine wider skis. . Does anyone have any insight as to how they compare to one another?
I found myself being the black sheep in the backcountry and noticed the skis loved to sink and the track loved to trench.. I am hoping someone out there has done the upgrade after some seat time on a stock xtx and can give me a good comparison and if these upgrades made a substantial difference.
Thanks all.
Thanks all.
Joshua
- Apr 14, 2010
- Newfoundland
- 2018 Yamaha Sidewinder BTX LE 50TH
Mind is doing the same thing with a 2.25'' track and stock skis. I just ordered a set of 8'' powder hounds. Hopefully this will solve the issue.
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Thanks all.
PM NOS-PRO.......he did that change earlier this season.......although he did use Cat 153" rails but for sure it was a 2.25" Powderclaw track......he'll tell you whatever he can about it........he's back to 141 track now.......
subaru2006
I run slydog powder hounds 7" and they rock. The back I also have no issues with just not sure what the settings are since I did it 2 yes ago and left it. My combo works great on and off trails.
Subaru2006
Subaru2006
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I have 8inch slydogs and 2.25 on the xtx le. Works very well off trail. We also have xtx se with 1.6 track and 8inch skydogs it very capable just needs a bit more momentum in the deep. If the skis are sinking in the snow you're going to trench so a wider ski helps this alot. The wider ski will also give you alot more control on a steep side hill also . wide skies are the key off trail. I think both tracks are great.
stingray719
Thanks all.
Been there done that...twice.
Wider skis, and MOST important put a 160 pound spring in the front skid shock. The combination will stop the nose dive on decelleration. Turns Viper from heavy steering sled into a pure joy to ride. The trenching comes from WAY to much weight on the skis and back of the track. The change is day and night from stock.
http://www.ty4stroke.com/threads/interesting-skid-shock-spring-info.131147/#post-1177413
- Apr 14, 2003
- Hessel, Michigan
Yes, need different skis (wider than stock) to keep floatation. Used the C&A Pro skis, worked very well, but now have powder hounds (haven't tried yet but know they will work better than stock)
nherbst454
I use C&A Pro XTX and the front end stays up very well compared to the stock skis.
Yammie4life
I got 2.25 track, and 7" slydogs on XTX LE. Love it
Yamadog
I have a pair of the massive simmons mountain skis. I was going to try them this year but never got enough snow. Thought it would look funny trail riding with 12" wide skis. I had them on an old 03 RX-1 ton Turbo and they worked great.
juniorXTX
Thanks folks. I think that this track and ski upgrade will be in the cards for me the fall. I have done a lot of reading about it and people seem very pleased with that track.
Groomer08
i couldnt imagine what hyfax wear will be like. i smelt mine cooking many times and even had to replace at 2k miles.
as far as off trail, skis def help, but letting the limiter strap out helps more.
i run simmons on all my sleds, so the front end stays up top.
found the viper to do pretty good off trail, never really burried it this year.
edit: 1.6 cobra track
