yamaha apex supercharged iac valve
I hooked my IAC to the intercooler. everything is good.
I am running 8.7 psi at 10700 rpms . Running 24/24 gears on the supercharger.
I have it set with my gems controller to run at 11.7 at wot.still running to rich mid range 12.5 no boost.
Light load.I also have a bypass valve
The IAC is closed at WOT? (not allowing any bypass?)
What do you mean not allowing any bypass ? Like a blow off valve
no, I mean that the IAC should be sealed (so to say) and not leak any air to atmosphere at WOT.
