GreenMtnRx1
I have a 2006 apex with the stock primary flyweights is there a yamaha flyweight with the same cuvature but heavier. I like the engine braking and it has a good straight shift but I want to lose 500 rpms.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
change the rivets to heavier ones. 2 grams in the tip ???? to pull @500 rpm down. someone correct me if I am wrong on the grams.
GreenMtnRx1
I have the 4.5 gram rivets in the flyweights. I don't think there is a heavier rivet. Maybe I will try a lighter spring first.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
We have some made up with lead rivets home made that work good,pm me for info.GreenMtnRx1 said:I have the 4.5 gram rivets in the flyweights. I don't think there is a heavier rivet. Maybe I will try a lighter spring first.
Len Todd
Where is it running at anyway?
Depending on where you are at with Secondary twist now, why not just take 10 degrees off the Secondary's Wrap. That should drop your RPMs by 300-500. It will try to up-shift faster and load the Engine a bit more.
RTX Rox
A lighter spring is cheating. It'll effect your engagement too. Adjust your RPM's with the weights
Len Todd
You could also weld on the back of the weights and then match them back up by filing them back a bit until they all weight the same. You will need a gram scale to match them up. We used to do this on out Arctic Cat weights, a long time ago.
