Nytroed
Hello everyone I have a 08 nytro that runs lean with fuel control box maxed out. The sled used to have a 240 kit now has 180 switched fuel control box and nothing. Mpi has been 0 help anytime I called. I ride 7-10000 ft and 7-8 # of boost. Sled seems to run OK till you try to gain rpm then a pop and Afr jumps to 20s. Anywhere to start?
Are you sure your AFR sensor is good? What fuel controller are you running?
Nytroed
I have changed the sensor and the fuel controller. I have the gems controller. The fuel pump is a mpi upgrade but it starts weak then turns to a fast squeal. Not sure if that's normal.Are you sure your AFR sensor is good? What fuel controller are you running?
If you have the gems maxed out and the AFR is lean, you have the wrong controller.
kingtut
I was also thinking this. Anyone near you have a 180 kit?
Nytroed
I have the 240 controller and the 180 controller and have swapped them back and fourth no change. I am the only 4 stroker out here.I was also thinking this. Anyone near you have a 180 kit?
Something else does not add up.
is the fuel pressure dropping on it?
Nytroed
That I'm not the only 4 stroke on the mtn? Ya tell me about it I've scrambled everything that I could think of I am a pretty decent mechanic and I understand most all of it. Any other thoughts?Something else does not add up.
Nytroed
I'm not sure my pressure tester will be in tonight. I wonder if the injectors are malfunctioning?is the fuel pressure dropping on it?
I have installed an Apex Charger that run ok until I added a little box from Dave at Hurricane and 2 Nytro Chargers and they have worked pretty good box stock 180hp at sea level. Could be fuel pressure or a bad controller.. I am at a loss. If you don't like dealing with MPI, contact Dave at Hurricane. I had a strange spot in my first Apex that he figured out for me. I was chasing my tail for 2 years on it.
Nytroed
Ya I am going to check the pressure this weekend. And I will have to try to find his his number and see what he says. That's kinda where I'm at!I have installed an Apex Charger that run ok until I added a little box from Dave at Hurricane and 2 Nytro Chargers and they have worked pretty good box stock 180hp at sea level. Could be fuel pressure or a bad controller.. I am at a loss. If you don't like dealing with MPI, contact Dave at Hurricane. I had a strange spot in my first Apex that he figured out for me. I was chasing my tail for 2 years on it.
I wish I could be more help. Hard to help when you can be there to actually hear and see what its doing. Daves number is 613-925-2019, thats the last number I show or check online https://www.facebook.com/Hurricane-Performance-Canada-Inc-655887444516904/
Nytroed
Hey thanks I appreciate it all everything helps! This Colorado weather is changing towards winter I hope and I want to ride the fat nytro my little my 850 is too light and nimble. I kinda like to feel like I went to the gym a day or two! LolI wish I could be more help. Hard to help when you can be there to actually hear and see what its doing. Daves number is 613-925-2019, thats the last number I show or check online https://www.facebook.com/Hurricane-Performance-Canada-Inc-655887444516904/
Nytroed
So I lifted the track and 13.9-14 at idle 11.2 at 2500rpm 13 at 3000 Afr then a fast roll into full it jumps to 20s-30. 1.5 # at idle. Pressure Gauge hasn't showed up yet any thoughts with new info?
