So I lifted the track and 13.9-14 at idle 11.2 at 2500rpm 13 at 3000 Afr then a fast roll into full it jumps to 20s-30. 1.5 # at idle. Pressure Gauge hasn't showed up yet any thoughts with new info?
It's maxed out on them and seems to make no difference on the controller either way they are set. It has a few cut outs when you give it throttle then when you let off it seems to almost die but come back to an idle.If the motor is not loaded it wont build boost either. It sure sounds like the map is extremely lean. What are the setting on the gems at each light stage?
