gregdec1
Does anyone happen to know what size the factory Nytro MTX bar riser is? I am considering putting it on my XTX along with the extended brake lines and throttle cable.
towerrigger
6 inch
If your going use your XTX handlebars with a MTX riser your going to have a MEGA tall handlebar set up. Let me explain. The Handlebars on your XTX have about 3 or 4" of sweep/rise to them. The Handlebars on a MTX are alot flatter and only have about 1" of sweep/rise. So if you've sat on a stock Mountain MTX and liked it, you better take into consideration your going to be another 2+ inches taller if your using your stock XTX handlebars with the MTX Riser.....
Nytro XTX Stock uses no riser and bars that have 3 to 4 inches of sweep or rise.
Nytro MTX uses a 6" riser with Handlebars that have about 1" of sweep or rise.
Sorry if you all ready knew this, just thought I'd better post incase you didn't look at it that close.
gregdec1
Thank you for the info. I did not know that. In that case it would be to tall. I already have a 2 inch riser on there but it still seems like I am slouching forward a bit when standing up. It may be a good idea to go with a 3 inch riser instead. Not sure what I will have to do to extend the brake cables and throttle cable though. Even with the 2 inch its just a tad bit tight. Is there a way to extend them without changing them somehow. Reroute maybe.
Fly makes and adjustable riser in the range you're looking for.
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
got the OFT relocator yet??? do this before anything else...
Mountaintech
raginyamaha said:got the OFT relocator yet??? do this before anything else...
I second that.
