NyTrOMaNIaC
Just wondering if there is a useful tool for Yamaha primary clutches that makes it easier to take the clutch apart when changing springs or weights ? I've used them on my Rev years ago and they made clutch work a lot easier, just wondering if Yamaha or someone makes one for these clutches ? I read that some guys were just going out and buying a long threaded bolt and using a LOT of washers, but I'd like to have the proper tool for the job. Appreciate your help or advice
For spring & weights, no need for a tool.
Cover removed, if you look closely there are 6 plastic like buttons on which the moveable sheave slide. In order to service those one must unscrew (clockwise) the spider from the fixed sheave.... this is where special tools are required... pricey i suppose.
NyTrOMaNIaC
I knew there was a tool out there. Bunker Hill Clutch Dummy Tool, guess I'm the only dummy who wants one
J&T is one of the few distributors I've found for it incase any other dummies are interested
It allows you to be able to change springs or weights in the primary right on the trail with the clutch still on the sled, and the reviews I've read on it are excellent.
http://www.jtatv.com/SearchResults.asp?Cat=7
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX (on order)
2018 High Country 9000
2001 SRX 700
Is it usable to put back in the big HC spring?
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
2001 SRX 700
I think i will buy one. And they says it will work with any spring lenght or stiffness. So they should be able to work with the HC's.
NyTrOMaNIaC
I haven't received mine yet, so I can't say from experience, but the details say any spring, so I assume that includes the HC spring. I'll find out this week and report back.
