TrxR
- Dec 20, 2007
Anyone here ever work on a Terrapro? Specifically has anyone ever replaced the right side rear wheel bearing?
Ganz
Never heard of it. Got any pics?
TrxR
- Dec 20, 2007
looks like it comes apart like the sra big bears to me but i think we will need pic's with the tires off if you would.
TrxR
- Dec 20, 2007
Here is the best look I can get of the housing right now. Here is a parts diagram as well. As you can see in the diagram they list the whole shaft as one piece (69) what I am hoping is that it has a bearing on it that is replaceable. PS that shaft is discontinued
yup. then it is the same procedure as a straight rear axle. i know al balls makes a kit for replacing both axle bearings with all the nessasary seals to do the job. the shaft can be re-built on the splines. i knw there is a guy locally that does it but the dealer that was dealing with him is closed now. i got my uncles 1992 big bear axle rebuilt when he stripped the spline on it for the diff. the biggest thing is the axle must be straight.
