stgdz
- Mar 27, 2021
- Buffalo MN
Can any one tell me how dealers handle tunes and warranty coverage? This is my first rodeo with a yamaha and warranties, I typically do all the work myself so going to the dealer for repair work is a bit......
odd
odd
mario750
They not gonna cover blown motor, ask me how I know
Jd2859
- Dec 2, 2019
- La Crosse,Wisconsin
- 2020 sidewinder LTX GT
Couldn’t you just put stock tune back in? or does the ecu have something stored where they can tellThey not gonna cover blown motor, ask me how I know
It’s been tuned?
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
They sure can tell, i think it was in kingers sidewinder post that showed pages of info that yamaha (& all others)can retrieve from the machines ,if max boost or rpm for instance are higher than oem they know it was tuned even if it isn’t currently, same applies to trucks, cars& most anything with a computer, same idea as files/messages that are deleted that are still in the phone/ computer etc( somewhere) unless you physically destroy the computer it can be retrievedCouldn’t you just put stock tune back in? or does the ecu have something stored where they can tell
It’s been tuned?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I think a lot of it depends on what you are trying to get covered and what kind of relationship your dealer has with Yamaha.
SledFreak
- Feb 7, 2005
- Ontario. Canada
A good dealer can make it work, but a different ECU would be the better route like say a recked sled and then when you have issues, swap in the stock one.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Yes, Everything thing is timestamped and the ECU is tied to the VIN of the machine.They sure can tell, i think it was in kingers sidewinder post that showed pages of info that yamaha (& all others)can retrieve from the machines ,if max boost or rpm for instance are higher than oem they know it was tuned even if it isn’t currently, same applies to trucks, cars& most anything with a computer, same idea as files/messages that are deleted that are still in the phone/ computer etc( somewhere) unless you physically destroy the computer it can be retrieved
stgdz
- Mar 27, 2021
- Buffalo MN
In order to transfer the warranty a yamaha dealer has to inspect it correct? One of my neighbors has two winders and told me that was the case with one of his.
Story time, he picked it up last fall but before he got it the guy told him it was overheating. They called the dealer and said we know about that one. Well they found a cracked front cooler and replaced it under warranty after the title transfer.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Interesting, never heard that....In order to transfer the warranty a yamaha dealer has to inspect it correct?
SledFreak
- Feb 7, 2005
- Ontario. Canada
Thats not true... If they are supposed to, they dont do it.. I have had warranties transferred over the phone.
Firedawg1998
- Oct 17, 2018
- Sudbury, Ontario
- 2019 srx
Hurricane PM bundle
2012 apex xtx
2012 vector gt
I just did my warantee exchange. Ontario. I had to send Yamaha my new ownership, bill of sale, mine and original owners drivers liscence...
The warantee follows the vin in Canada.
Cat friends had to do nothing, follows the vin he was told.
In the States, I read an inspection is needed to be done by the dealer, paid for by the new owner....that bites...
