Yammi-Rider
I have decided to change my swaybar on my 05 RS Venture to reduce the inside ski lift...not sure which one yet 12mm or 13mm. My question is does the larger swaybar fit the stock links?
I assume the 12mm & 13 mm means the diameter of the bar itself, however are the spline ends the same diameter as the stock bar or are they 12mm and 13mm as well? If the ends are 12 or 13 mm how will that fit in the stoch links?
NY_Nytro
- Dec 24, 2004
- Grand Island, NY
- www.gi-snowmobiler.com
Yes the 12 & 13 will both fit with the stock links
I use the 13mm & very happy with it.
This will not prevent ski lift.
In fact, you will find yourself going faster in corners up until you lift again. It will just push up your actual threshold. One thing you will notice however is that it will be less spongy so that youre more comfortable & on control during a given sky lift.
Yammi-Rider
Thanks for the response guys.
aVenture I assume you have these on an RS Venture judging by your name...aVenture
