zachalyse
- Oct 20, 2005
How tight are you guys running your track? I had mine set to have a gap of about 1 1/4" under 22 lbs of pressure in a 50 dagree garage. Then I started reading that it should actually be set fairly tight.
My big concern is that I'm running a 1 1/4" track in an SRX with 1.185" studs and want to protect my heat exchanger.
So, how tight I should I set the track? What's the pros and cons of too tight or loose?
tkuss
Check the manual, it varies with temperature. I believe at 70 farenheight there should be no gap and at about -14 farenheight there should be about an inch and a half gap.
kinger
I follow the manual closely however in my 70 degree shop I have about 1/2" of sag, I figure with my extro drivers I wont worry about ratcheting. I love how when I get to stop it just rolls and rolls.
zachalyse
- Oct 20, 2005
Mine must be way too tight. I certainly don't roll and roll when I stop.
kinger
Yeah I have to actually use the brakes when coming up to a stop, I was impressed its never done that until I added the ZX2.
Try 1/2" of sag at 70 degrees in the shop and see how you like that.
Shane
- Dec 21, 2004
- Niskayuna, NY
- www.fa.ml.com
- 2014 YAMAHA VIPER LTX SE
2015 Ski-Doo 800 XRS Renegade
2012 Ski-Doo 600 ace
2010 Ski-Doo 600 e-tec GTX Limited
2007 Polaris Dragon 120
I have found that running mine loose is far better. I run as loose as possible so that it only ratchets once in a great great while when really getting on the throttle hard from a stand still with great hook up. This extends the life of the hyfax and allows for much greater roll when getting off the gas. Additionally it allows the suspension to work more fluidly.
