Custom Rx1
- Jan 16, 2007
Dose any one know if the ZX2 can take the added HP of a turbo.
I may want to put one on but need to know if it will break the ZX2.
LazyBastard
According to adboivin, it is not tested with turbo. They say it *might* hold up, but for the time being are recommending turbo users to stick with expertx, which is proven to hold up great to crazy power.
Jeff\ADBoivin
The ZX-2 won't brake or crack.
The turbo guys may have to go with the in/out drive spockets.
We have not tested that kind of horsepower before with the ZX-2 and what i need to valid is the track racheting on the drive spockets.
The Expert X for the turbo sled is the best overall suspension. it as proven itself over the year and is bullet proof.
Plus a 121'' Expert X set back to 136'' will give you a smaller angle of attack for better top speed.
The adjustability of the ride height from the lake run(low) to the trail riding (high) can be acheive in a matter of minutes.
This is the hot cake for the turbo sled !!!
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Yep, that;s what I got. I'm running a 136" Expert X set back to run a 144: track on my Supercharged sled. My Expert is absolutely "Bullet Proof" as said above.
You'd have to pry that skid from my cold dead hands. lol
-1CS
-1CS
Jeff\ADBoivin
It is good to ear comment like this!
thank 1CrazySledder !
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Jeff\ADBoivin said:It is good to ear comment like this!
No problem. I'll give credit where credit is due.
-Vince
SPEED
Vince
Are you running stock drive sprockets or did you change them.
I am going to run the 121 x-pert in my Attak. My last x-pert was in a warrior with NOS.Never had a ratcheting problem with that one ,Just curious
Art
Art
Custom Rx1
- Jan 16, 2007
So we can run the turbo with the Zx2 just may have to use different driver's in the track. I think you can use stock if you do not go to high boost.
Turk
Tech Advisor
With the xpert skid you also don,t need anti-ratchet drivers ; even at hi boost.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
Turk said:With the xpert skid you also don,t need anti-ratchet drivers ; even at hi boost.
WHAT!!!
Don't tell me this. I spent 180 bucks on Extroverts. I am running the expert. You don't think I need the extroverts then?
-1CS
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
money well spent , be happy !
Turk
Tech Advisor
I didn,t need em running 12 pounds boost on a freeride 136 track & hooking hard. No/none/zip ratcheting at all ever. Just hang on & go!
