Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Are these four parallel running bogies necessary?
Can I remove the forward set?
In what way would they affect my sled? Ty....
RAMSOMAIR
On my 2016 Viper I removed the wheels that were common with the shock shaft. Put 2 old bearings in their spot to take up the space on the shaft and then added 2 wheels and mounts to the outside in that general loacation.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
because of the mounting of the front control arm.... all the dwn wrd force is right where those wheels are, your slides would wear faster if they are removed.... but thats up to you
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, just thought it was redundant.On my 2016 Viper I removed the wheels that were common with the shock shaft. Put 2 old bearings in their spot to take up the space on the shaft and then added 2 wheels and mounts to the outside in that general loacation.
Ok & understand.because of the mounting of the front control arm.... all the dwn wrd force is right where those wheels are, your slides would wear faster if they are removed.... but thats up to you
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Forward set would then cause contact from the drive lugs and cross shaft.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Also those wheels help drive the studs in center belt into the ground
Doc Harley
- Oct 17, 2016
- Here & there
I buttoned it up with those wheels on. Ty d.p.Also those wheels help drive the studs in center belt into the ground
