Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 14600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 19500 km
2010 Vector LTX GT 25000 km sold
I was out riding last weekend and and my dash went blank, the backlight was on but no display, no indicator light or high beam and no handwarmers/thumb warmer. Head light and tail light were working. Once I got home I shut off the sled and when the sled was restarted everything was working. Anybody else have this happen and what was the fix. I got a trip planned in 3 weeks and really don't want any issues coming up. Thanks for any input.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Relay. Could have been froze up. Once the engine warmed underwood it came to life. Pretty common thing, can be the dash relay and typically the fuel pump really freeze up. Warm them up and they'll work.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
I know what your saying but I was in the middle of my ride on the way home when it went blank, wasn't very cold but hopefully it was relay related.
Still can be the relay. This happened to me last year while riding and it wasn't very cold.
Turboflash
- Mar 18, 2019
- Southern MN
The stock relays are not waterproof and can get condensation inside them (from freeze/thaw cycles) which can cause intermittent connection. Might want to invest in the waterproof ones.
One other possibility is short or cut wire up by fuse block. Check main harness going into fuse block. It rubs on the metal bracket up there and can rub through or get cut or shorted.
Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
Best solution is to replace all the relays with auto relays. Scrap cars and trucks are perfect donors. They always started.
The latest are all water proof.The stock relays are not waterproof and can get condensation inside them (from freeze/thaw cycles) which can cause intermittent connection. Might want to invest in the waterproof ones.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
I'll check my wiring harness and I'll get some BOP relays.
