Savage
- Apr 29, 2013
swamped the quad and the coil and the ground wire all melted, i assume that taking in water over loaded the coil and it burnt up. It melted the crimps for the grounds to the cluster and every other ground in the harness, also at the engine block where the ground grounds. Anyways i have it all apart and theres a plug end off the harness under the cluster that has 4 of 5 wires to it and some kind of metal peice in it, im wondering what it was, the diagram yamaha gave me is not very detailed.
anyone else had a problem like this? or know where to get some better wireing digrams from?
Savage said:swamped the quad and the coil and the ground wire all melted, i assume that taking in water over loaded the coil and it burnt up. It melted the crimps for the grounds to the cluster and every other ground in the harness, also at the engine block where the ground grounds. Anyways i have it all apart and theres a plug end off the harness under the cluster that has 4 of 5 wires to it and some kind of metal peice in it, im wondering what it was, the diagram yamaha gave me is not very detailed.
Can you post some pictures?
Savage
- Apr 29, 2013
I don't know how to make the picture smaller using my phone
Savage
- Apr 29, 2013
While I have the front plastic off, are there any kind of problems that anyone knows of with other components that would be easy to change while I have it apart.
Change the pics to 640x480 in the phone settings.
Savage said:While I have the front plastic off, are there any kind of problems that anyone knows of with other components that would be easy to change while I have it apart.
Take a look at the front diff, change fluid, check over CV boots and bearings.
Savage
- Apr 29, 2013
The peace I was looking at is a ground block
Gotta wait for the new coil. Then hope my cdi is good
Savage said:The peace I was looking at is a ground block
There must have been a short some where. I have never heard of a unit being submerged when running causing that kind of damage.
Savage
- Apr 29, 2013
I'm good a fn stuff up.
It had to have been arching out at the plug.
Savage said:I'm good a fn stuff up.
LOL, get some pics up of your progress... if you want to send them to webmaster@totallyamaha.com, I can help you get them sized correctly.
Savage
- Apr 29, 2013
Just got the coil today and got it installed and all my grounds repaired and added a fuse. But I still do not have spark,I have no power to the coil.
Savage said:Just got the coil today and got it installed and all my grounds repaired and added a fuse. But I still do not have spark,I have no power to the coil.
Are you getting power out of the Stator?
Savage
- Apr 29, 2013
just about to look at it, looking for some more info on what wires to check
Savage
- Apr 29, 2013
Well there's 2 plugs one has 3 wires the other 4
The 3 wire plug has continuity
The 4 wire plug has continuity between the red and white/blue wire
the white/red and white/green wire do not.
From what I've been reading that not good, what do you think?
Savage said:Well there's 2 plugs one has 3 wires the other 4
Sounds like thats shot...
