7mw
Hey guys just joined I have owned my 07 phaser 5+ yrs and has been been a great sled with minimal issues
Always has had intermittent starting issues and last season it finally wouldn’t start for me
Sometimes it would randomly stop when idling then u would start it and it keep on going no problem
Just went through the painful starter ritual grinded and completely removed useless casting tab and changed my starter.
Topped up my oil and reinstalled my head light and looks like air filter front assembly. Plugged hose back in going from oil tank to housing etc.
Once I connected battery back I turned one click over and primed it I believe, did that once more, then cranked it over and it started
Then shut off 5 sec later on it’s own agian tried it takes a a second or two and turns over then shuts off shortly after
I have code 14 and 26 now showing with engine light and red light not sure what is going on now everything looks like this without the codes before I changed starter it just wouldn’t start at all before I changed it
Thanks agian
Thanks agian
Phazer Error Code: 14 & 26
Was working on the Phazer, and after reassembly I am seeing Yellow Caution light keeps blinking / Engine Light blinking on Display Error Codes 14 & 26 alternating back and forth Code 14: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #1...
www.snowest.com
7mw
Yes I did and the large hose I didn’t get it complete all the way up as it such a hard spot but I got it seated good I feel is there any other hoses I’m missing ?did you plug the tiny hose back in
7mw
Now that I think about it Kevin there was one more small hose at the bottom of housing but I thought it was a drain lineYes I did and the large hose I didn’t get it complete all the way up as it such a hard spot but I got it seated good I feel is there any other hoses I’m missing ?
the electrical plugs for the air pressure sensors plugged in, same sensor that the small hoses go to?
7mw
I believe so there was two plugs and I connected themthe electrical plugs for the air pressure sensors plugged in, same sensor that the small hoses go to?
2007 Yamaha PHAZER FX (PZ50FXW) Intake | Babbitts Yamaha Parts House
Shop online for OEM Intake parts that fit your 2007 Yamaha PHAZER FX (PZ50FXW), search all our OEM Parts or call at (231)737-4542
www.yamahapartshouse.com
for picture reference.
From what i have found on the codes:
Code 26: Intake pressure sensor hose problem.
Hose is detached, loose, plugged, pinched, etc on Cylinder #2
7mw
Looking at the diagram hose #5 hose #31 I both reconnect to machine but hose # 29 I left hanging down[URLunfurl="true"]https://www.yamahapartshouse.com/oemparts/a/yam/5003c344f8700212fc841ef1/intake[/URL]
Shop online for OEM Intake parts that fit your 2007 Yamaha PHAZER FX (PZ50FXW), search all our OEM Parts or call at (231)737-4542www.yamahapartshouse.com
7mw
Is it possible the sled lost oil prime from losing oil out the starter ?Looking at the diagram hose #5 hose #31 I both reconnect to machine but hose # 29 I left hanging down
On bottom of each sensor that goes in the airbox that those electric plugs go into there is small hoses that go on bottom of each. very tight to see.
7mw
Hmmm I believe so hose #5 you are referring to?did you plug the tiny hose back in above the airbox?Phazer Error Code: 14 & 26
Was working on the Phazer, and after reassembly I am seeing Yellow Caution light keeps blinking / Engine Light blinking on Display Error Codes 14 & 26 alternating back and forth Code 14: Intake pressure sensor hose problem. Hose is detached, loose, plugged, pinched, etc on Cylinder #1...www.snowest.com
7mw
I don’t recal a small hose under each I will double check for that !!On bottom of each sensor that goes in the airbox that those electric plugs go into there is small hoses that go on bottom of each. very tight to see.
Yamaha Phazer 500 Pressure Sensor 2007 #3 | eBay
Yamaha Phazer 500 Pressure Sensor 2007 #3 in Good Condition.
www.ebay.com
these photos should explain
7mw
I get a sense more of what you are talking abt now I don’t think I removed the sensors but I will need to go double lookYamaha Phazer 500 Pressure Sensor 2007 #3 | eBay
Yamaha Phazer 500 Pressure Sensor 2007 #3 in Good Condition.www.ebay.com
7mw
Wish I could see those hoses in the schematic btw ty for all the help !I get a sense more of what you are talking abt now I don’t think I removed the sensors but I will need to go double look
