welterracer
What was the weight , HP, and top speed of this sled!!
We were having a debate about it at work today i said Top speed is 65!!
my 1974 gp 433 went 75 mph on radar gun bone stock might have been 1973 to much beer back then :? but i remember the the cop (DAD) set up in the front yard man that was fast back then :lol:
welterracer
TTT
vmaxjohn
Our '80 Enticer 300 would run 65mph...my cousin had a late 70's Exciter 440, it hauled #*$&@ for a little sled. I'd say more like 80 or possibly better, really!
Traildemon
I had a 76 & a 79 440 Exciter. It probably only weighed 350lbs.Remember it was fan cooled, like most sleds back in the day ! with a simple leaf frt susp. & about 3 in. of travel in the back :? I think it had about 65-70 hp.Ran well for a single carb.seem to remember seeing 80-90 mph .The 76 was actually quicker , but had terrible fuel mileage- about 6-8 mpg :shock: with only a 6 gal tank. Was always getting towed into town even after strapping cans to the running boards ! In 79 they changed the carb & upped the gas tank to 8 gal :!: which helped greatly. overall a great sled :wink:
YAMAHOWIE
I have a pair of 80 440 Exciters that have been together since new. I am the third owner and the serial #'s are 5 digits apart.They both run 80+.
yamrx-1
I have a original sales book from Yamaha Here is everything they give on the EX440C, Drive System ...Internal Drive , Track ... Fiberglass reinforced rubber, Suspension ...Slide Rail with idler wheels, Trans ...Variable Ratio Automatic, Weight ... 176 kg(338 lbs.), lenght ...2520 mm(99.2in.),width ...980mm(38.6in), Heght ...995mm(39in), Ski Stance ...800mm(31.5in), Brake Disc, Fuel capacity 8 Gal., Oil Capcity 3US qt, TYpe 2-Stroke , Induction Torque Inductuin (reed Valve), Dissplacement ...433CC, Bore and Stroje 68x59.6mm, max Horsepower ...48bhp @7000 rpm, Max Torque 35 ft lb @7000 rpm, compression Ratio 7.0:1 Lubercation ... Auto lube, Carbure Keihen BD44-38, Ignition CDI, Starting Manual Recoil... Hope this Helps...
welterracer
THanks that sums it up for me!!
