DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Are there clamps on the boots ? Everything should be taken apart and inspected in the air box . Make sure everything is sealed correctly and not with RTV . If it reved up with the carb cleaner then its a problem . Fix that issue and change plugs and I'm guessing it will run .
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Yeah the engine would pull false air right? Think you're onto something
It appears the air box has been repaired with sealant of some sort. There is also some visible around the the carb boots on the air filter side. Is this factory or did the previous owner do this? Also I was able to spray starting fluid around that same area and it made the engine idle go up so clearly it’s getting by, just don’t know if it’s enough to make a significant impact..?
i need to see a pic as the factory does use a touch of sealant to hold the boots to the air box but it looks gold/brown in colour.
theCATman
- Feb 19, 2007
- WI
- Yamaha
CV carbs, so ANY amount of "unmetered" air will make the engine run like $hit.
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
clamps are on the boots and the sealant is brown in color. i wasnt aware that they used sealant. i fixed the one boot i thought was leaking and the sled will go alittle over 80 now but not as responsive i think it should. so im getting closer. the sled has about 6600 miles on it. im wondering if the clutches need a little servicing?Are there clamps on the boots ? Everything should be taken apart and inspected in the air box . Make sure everything is sealed correctly and not with RTV . If it reved up with the carb cleaner then its a problem . Fix that issue and change plugs and I'm guessing it will run .
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
"any"? really? i never would have guessed a 4 stroke sucking alittle air would have such an impact. Also what are "CV" carbs? Im unfamiliar with that nameCV carbs, so ANY amount of "unmetered" air will make the engine run like $hit.
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
yeah thats the stuff.i need to see a pic as the factory does use a touch of sealant to hold the boots to the air box but it looks gold/brown in colour.
theCATman
- Feb 19, 2007
- WI
- Yamaha
CV stands for constant velocity.
When you open the throttle, all you're opening are the throttle blades, much like on a fuel injected engine. The carburetor(s) rely on sufficient engine vacuum to open the slides. If you have an air leak, it's loosing vacuum and the slides won't open properly.
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
Cleaned my clutches and noticed more response, not taking interest in top speed.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
When you cleaned the clutches, did you wrap the secondary spring to spec correctly? I've made that mistake on an occasion or two.
05VectorDV
- Feb 14, 2020
- new york
- 2006 apex ER
update, the o-rings on the individual choke plungers where warn out and not sealing, replaced and all is well
