RobX-1
- Coldwater, OH
Would the vent tube be the furthest on the right? Its aluminum -> rubber hose -> to alum.
That red arrow in your first pic is pointing to the throttle cable and not a vent tube or hose.
the movement you are seeing is the tors switch in the throttle block. helps stop a runaway sled when throttle cable freezes/sticks open. movement there has been normal since the mid 80's on a yamaha.Okie dokie. Did some more digging.
Understood on the plug boot/coil. MAN, those are long (that's what she said). So before I go yanking on those, I'd like to see if I can get the carb bowls full.
Rob-X: thank you for the exploded view pic. It's likely just me but Im not 100% if I am seeing the right thing. First pic in this post is a view of the engine from the front. Would the vent tube be the furthest on the right? Its aluminum -> rubber hose -> to alum.
In the same pic, the top red shut off is currently set to ON. I assume the bottom one follows the same position to be on? Ie. both pointed up?
For the throttle: the throttle has pressure when i push on it (as if to give it power). When I push the throttle, the rail on the carbs moves back and forth smoothly. Im more talking about ... the whole lever is just loose. In the two next pics: first one is what I believe to be the proper 'position' of the throttle mechanism. It's only here when I hold it in place. The second pic is where the throttle sits without being held. Its 'off center' so to speak. If I jiggle the throttle, it bounces around .. yet the cable stays taut, if that makes any sense.
Se7enOfMine
- Jan 30, 2022
- Vankleek Hill, Ontario
- 2007 Yamaha Venture RS
1996 Ski-Doo 583 MXZ
Huh. I so do not remember there being that much play there last season. Its only once the cover was off that i noticed it. So weird.the movement you are seeing is the tors switch in the throttle block. helps stop a runaway sled when throttle cable freezes/sticks open. movement there has been normal since the mid 80's on a yamaha.
Gonna try getting her started today. I noticed that one of the lines from onr of the pumps to the rail has a kink in it so gonna go get some replacement hose and change that.
RobX-1
- Coldwater, OH
@maim is correct about the play. Maybe you just didn't notice it until this year but here are examples from 03 RX-1:Huh. I so do not remember there being that much play there last season. Its only once the cover was off that i noticed it. So weird.
08 Apex:
And 18 Apex. All normal:
Se7enOfMine
- Jan 30, 2022
Greetings folks,
So after a series of unfortunate health issues, finally got out on the sled today. Was a long time coming. But alas, didnt feel like smooth sailing.
Back when i posted the issues above, i got the sled started (was actually way easier than i thought it would be) but then the health issues crept up. Anywho ..
Went for a ride today. About 50km. I noticed something really bizarre (or what i feel is bizarre). It feels like the sled is very much over-revving. Very well hard packed trail, just myself on the sled (195lbs) .. at around 53-55km/h, revving about 6000rpm and at 70, around 7000rpm. Maintaining .. not butterflying the throtttle. Just maintaining speed. I feel like the power is still there but it feels like the engine is working way harder than it should be. It almost feels like its running one cylinder short. Belt looks good, deflection is ok. Havent really checked anything cause im not certain where to start (assuming there is actually something wrong and im panicking for no reason).
Anywho.... yeah, thats today haha
Se7enOfMine
- Jan 30, 2022
Also, just because ..hope you all are doing well. Its been a rough couple of months so it got me thinking about 'life' in general and putting good stuff out there. So i hope everyone is doing well, are all safe, n all that jazz
all the wheels in suspension turning freely?
ventures are clutched weird and soft so they tend to rev more and take longer to translate into speed.
Se7enOfMine
- Jan 30, 2022
Hmmm. I hadnt checked but i suppose its possible. I dont have a stand so it'll be tough to check but i will figure something out.
I just dont remember it revving that much last year. I know last season i had it up to 119 km/h and it didnt feel like it was revving as high as it was at 70km/h yesterday. As i say, 6000 at 53 or 54km/h seems awwwwwfully high to me. Id expect closer to 5000.
But, to be fair, i also didnt remember the extra play in the tors switch so wtf do i know? Lol
