Cdombro
- Jan 3, 2024
- Wisconsin
- 2009 Yamaha Vector Ltx Gt
Bought it not running got it fix and figured out my speed sensor was shorted out, replaced it then it work. Then it sat for a couple of days and now its back at zero the bearing looks to be good but have no idea what would be causing it to do this. Checked the sensor it is fine and works no damage to it.
What codes are displayed?
Cdombro
- Jan 3, 2024
- Wisconsin
No codes are displayedWhat codes are displayed?
If you drive it the speedo reads zero?
Cdombro
- Jan 3, 2024
- Wisconsin
Yes but at some points it reads a number then right back down to zeroIf you drive it the speedo reads zero?
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
Wire rub through and shorting out somewhere?
Cdombro
- Jan 3, 2024
- Wisconsin
Not sure going to take it apart tonight will keep you updated
No offence intended, but you do know the error codes are displayed if there are any?
Cdombro
- Jan 3, 2024
- Wisconsin
Yeah I thought it was werid but I have no codes displayed
Yeah thought it was weird but there are no codes displayed
Did you have the toothed speed pickup on the end of the drive shaft off by chance?
Cdombro
- Jan 3, 2024
- Wisconsin
No I cleaned it and have put it back on and there appears to be no wobble in the bearingDid you have the toothed speed pickup on the end of the drive shaft off by chance?
I find it odd that the speedo will read zero when you drive it yet there's no error codes.
Cdombro
- Jan 3, 2024
- Wisconsin
Thought that also is something that could be out that could cause the TORS not to send code?I find it odd that the speedo will read zero when you drive it yet there's no error codes.
Cdombro
- Jan 3, 2024
- Wisconsin
Turns out all it was the connector coming down for the handle bars was causing the TORS not to function right cause the speedo not get trough all the way clean up the connector not it works great
yam429
- Jan 18, 2009
- Saint Michael, MN
- Saint Michael
Glad you found the problem.
