FleuryPerformance
- Feb 23, 2019
- Alma
- 2018 Yamaha Sidewinder MTX LE 50th
I can confirm that even if main harness for cluster is disconnected, still drain the battery. It’s something else that I can’t find out at the moment. I’ll keep you informed.
Are you sure you don't have a dud battery?
Same. I make sure the battery has full charge when I put in storage. Don't unhook anything. No issues. Been doing it for years. They start right up when its time to use.Strange. I have a 2017 and 2020 and after the summer they are low but not dead. Always full charge them for the season and that’s about all I do.
FleuryPerformance
- Feb 23, 2019
- Alma
I’ve tried 2 brand new Yuasa OEM batteries and they both does the same thing.
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Man this is a typical Yamaha issue Aint it?. Same as the damn hot start, no start, cold start never had a problem start on the vipers. Seems random once again. I’ve been jinxed with them all it seems. Lol!
FleuryPerformance
- Feb 23, 2019
- Alma
Yes it’s sad. It’s sad because I love this snowmobile and electrical issues are the most annoying thing IMO.
FleuryPerformance
- Feb 23, 2019
- Alma
Hello everyone,
Did some testing again today. Here is what I found :
I've unplugged the connector that goes from the stator to the voltage regulator and the Amp dropped from 30mA to 25.7mA. After that, i've unplugged the bottom black connector from the voltage regulator and the draw completely stopped.
Since I dont want to buy parts for nothing, is there a way to test the regulator or this is a clear indicator that this is the culprit ?
Waiting for your help guys,
Thanks !
Thanks !
earthling
FleuryPerformance
- Feb 23, 2019
- Alma
Look’s like it’s the culprit. Here are my reading with my multimeter :
Positive side : 1-517, 2-0, 3-516
Negative side : 1-144, 2-144, 3-144
I don’t know what are the units of these number, but clearly the second value on the positive side is zero, there is my problem I believe !
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
From the manual. This is all they give to test.
A bad diode may also give a bad ac voltage reading.
You ever get this fixed? I have a 2018 with same issue. Parasitic draw on battery.Look’s like it’s the culprit. Here are my reading with my multimeter :
FleuryPerformance
- Feb 23, 2019
- Alma
Hello, yes it's fixed, it was the regulator/rectifier.
Everything work like it should now.
Thanks everyone !
Thanks everyone !
Awesome!! Good to know. I’m sure that’s what hats wrong with one I have coming in this month.Hello, yes it's fixed, it was the regulator/rectifier.
Thanks everyone !
