Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
The stock angle on an ADAPT Tcat Secondary is: 58/49.15 with a 120/220 spring. Has anyone improved upon this set up on a stock sled with stock gearing?
justinator
Adapt secondary is 58/49 full progressive not a compound cut like they used on the previous team equipped sleds. Always testing but had to go much shallower to get any belt grip at all on anything other than extreme hardpack, this was with stock sled.
Turboflash
- Mar 18, 2019
- Southern MN
Pretty limited availability of helixes for either Tram or ADAPT secondaries. There's a few but not many. I think there's only 3 stock secondary springs Cat sells.The stock angle on an ADAPT Tcat Secondary is: 58/49.15 with a 120/220 spring. Has anyone improved upon this set up on a stock sled with stock gearing?
dmarriner60
- Mar 31, 2022
- Mid coast Maine
- 2023 Riot 9000 on the way, 2014 xtx turbo, 2012 xf 1100 turbo, 2004 T660 turbo
I am trying to decide on a helix to give a whirl this year as well, thinking a little change and add some glide washers or just skip it and go straight to progressive spring
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
Anyone have any ADAPT helix advice? Anyone test something less than the 58/49?
Turboflash
- Mar 18, 2019
- Southern MN
You mean like less on both angles?
It's pretty common to hear stock ADAPT clutching is not right. Meaning engine runs too slow indicating primary weights are too heavy or secondary helix is too aggressive or secondary spring is too soft or a combination of these.
If so, first thing I would do is start lightening up primary weights.
Fords4life
- Dec 7, 2021
- South Dakota
Installed my bikeman torsional conversion from my rapid reaction team secondary right into my 2024 cat zr9000rr, works great with stock team 58- 48 so far for me, this means if you have cat team helixs laying around they work in the adapt.Anyone have any ADAPT helix advice? Anyone test something less than the 58/49?
justinator
yes team boss helix's work in the adapt but a factory cat adapt helix will not work in a team/boss clutch. The cat adapt helixs do not have the notches next to the roller slot so it will not drop into place on a boss. None of the aftermarkets are making adapt specific helixs so this problem only pertains to those looking to use a cat brand adapt helix.Installed my bikeman torsional conversion from my rapid reaction team secondary right into my 2024 cat zr9000rr, works great with stock team 58- 48 so far for me, this means if you have cat team helixs laying around they work in the adapt.
