ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I can't think of any other words to describe the problem.
My sled is difficult to drive through bush trails when I need to drive slow. The sled is way to aggressive when touching the throttle when moving at slow speeds especially when trying to get around trees etc.
How is this cured? I want the throttle to be smooth and be able to drive slow through the bush without bouncing off trees.
MTX stock clutching.
mach9
Clutch kit with softer rate spring.
or try the 14.5 rollers.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
Does anyone have any experience with the 14.5mm rollers?
mach9
There is quite a bit of info. and reading about options in this thread.
http://www.ty4stroke.com/viewtopic.php?t=104302
NFLD-Nytro
Cured? I thought that's what made the Nytro fun.
hearnoevil
I was thinking the same thing, I'd want her to jump more not less
ridding the weekend and the guy couldn't get over me stopping on the bottom of the hill then climbing up when everyone else was making a run for it.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
get a phazer
09nytro
That's funny but turewoolyviper said:get a phazer
bitchnblue09
clutch
Buy the comfort clutch from Schmidt Bros... smooth as a baby when going at low speeds...
yamaposer
Throttle
X2. Have the stage one kit from Schmidt and it works great. Smooth throttle and great mid range response
Schlick55
- Dec 3, 2010
14.5 Rollers and a Yellow Pink Yellow spring makes the Nytro a different machine around the gas pumps and loading on a trailer. A bunch of guys have done this and it works well.
Gear it down, low clutch engagement.
The nytro's love a low engagement.
nauti1
Re: clutch
I installed this kit a month ago. This kit does everything it says it does, lower, smoother engagement for tight manuvering. The Nytro throttle responce is what makes the Nytro so much fun, this kit just "calms down" the engagement harshness.bitchnblue09 said:Buy the comfort clutch from Schmidt Bros... smooth as a baby when going at low speeds...
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
How much is the Schmidt kit?
I don't mind aggressive throttle, but when going slow through thick bush to go ice fishing to remote lakes it is a pain in the arse.
nauti1
$149+shipping. U.S. This is what your looking for to make it nice and smooth at slow speeds and when backing up. You still have the great holeshots that the Nytros are famous for.It also reduces the engine brakeing somewhat.RX1MPete said:How much is the Schmidt kit?
