347strokin
pro116 said:Looks good.I should have mine done monday.I'm using a stock 05 r1 exhaust to keep the noise levels down around stock.Its titanium so its light too.
Sweet. You should post some pics! It's nice to see a few different ways to do things.
maverick
Very nice job! It looks a lot better than mine!
Two problems I've run into with mine. It's pretty loud and I'm not sure if it will pass the new Colorado regs. Second, in super deep snow, the sled bogs badly because the sled has trouble ejecting exhaust gases through the snow. Your pipe ejects further to the rear of the tunnel than mine so hopefully yours will do better.
347strokin
maverick said:Very nice job! It looks a lot better than mine!
I have heard of the bogging in the deep snow. Other guys say if I install a snorkel it won't be an issue. Worst case scenario, I will install an exhaust deflector. I just did the snorkel tonight!
pro116
Darn Mine won't woj the stock r1 exhaust is titanium.I took it to a weld shop an the they cant get it they even tried brazing it.I guess I will hve to go with an aftermarket exhaust.
Rx1M5
pro116 said:Darn Mine won't woj the stock r1 exhaust is titanium.I took it to a weld shop an the they cant get it they even tried brazing it.I guess I will hve to go with an aftermarket exhaust.
I had one of those a long time ago and if I remember right I ended up slotting the inlet pipe and using a T bolt to clamp it to the header pipe.
Rx1M5
PERRY CREEK BOONDOCKER
UNDER TUNNEL EXHAUST
NICE JOB! I AM DOING A SIMILAR PROJECT. WHAT ARE THE BENEFITS OF THE O-2 SENSOR? DO I NEED TO RUN ONE?
347strokin
Re: UNDER TUNNEL EXHAUST
Sorry about not getting back to you sooner. The 02 is there mainly for air/fuel tuning because my sled is supercharged.
PERRY CREEK BOONDOCKER said:NICE JOB! I AM DOING A SIMILAR PROJECT. WHAT ARE THE BENEFITS OF THE O-2 SENSOR? DO I NEED TO RUN ONE?
powder muncher
Not sure about those weld shop dudes---RX1 is all stainless steel.
Very easy to weld The Apex has some Ti peaces but the muffler itself is
stainless and very easy to weld.
niko
Well done, a great post on the mod. If its a little too loud you can add a baffle in the tip which works very well.
niko.
niko.
maverick
99669apex said:Nice job! What are the benefits of going with a tunnel dump exhaust? I think the twin pipes coming off the back of the Apex look pretty cool. How much weight are you actually saving by going this route?
You'd be surprised how much the stock exhaust system weighs that is eliminated. I'd bet it weighs at least 20 pounds, if not more. Plus the performance of a better-flowing exhaust and not to mention the improved sound, an under-tunnel exhaust is worth the trouble in my opinion. The only drawback I have found is in SUPER DEEP snow. The motor can choke on the back pressure caused from extremely deep snow (2 feet or more) clogging the system.
stubscat
were did you get your seat thanks donn
Firemann32
I thought about going further back with mine but I was concerned that the track might hit the pipe.
Pics of mine.
Pics of mine.
BigDogrx1
Nice job, where did you get carbon muffler, dimentions,and cost? Wonder if you can get one a little smaller?
