Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I've seen on here that guys have drilled the rivets that hold the belly pans on both sides out and replaced them with removable ones. Can anyone tell me what you used? Where to get them, and have they stood up to the abuse? If it helps, I'm in Cacnada but I guess I could order online.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Many have replaced with rivnuts. Do a search for ROCKERDAN’s build thread, it’s a Sidewinder but same chassis. He has great instructions and photos.
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Canadian tire, NAPPA, Princess auto have them.I've seen on here that guys have drilled the rivets that hold the belly pans on both sides out and replaced them with removable ones. Can anyone tell me what you used? Where to get them, and have they stood up to the abuse? If it helps, I'm in Cacnada but I guess I could order online.
https://www.princessauto.com/en/45-pc-threaded-insert-and-riveting-tool-kit/product/PA0008514234
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Amazon has a nice one.
https://www.amazon.ca/Riveter-Rivet...ocphy=9000231&hvtargid=pla-491795442399&psc=1
Grunt
- Nov 21, 2021
- Forest Grove BC
- 2016 Viper MTX
Good Bye Pop Rivots
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
I just did mine and used this Riv-nut tool kit worked well! I also took Rockerdans advice! only note is no need to drill out rivets around the exhaust pipe as I ended up just putting rivets back in.
Rivet Gun Kit Thread Setting Setting Tool Nut-Thread Hand Riveter with Rivit Nut | eBay
Find many great new & used options and get the best deals for Rivet Gun Kit Thread Setting Setting Tool Nut-Thread Hand Riveter with Rivit Nut at the best online prices at eBay! Free shipping for many products!
www.ebay.com
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I'm missing something here... doesn't putting rivets back in defeat the purpose? I would think you want them all replaced so it becomes a bolt-only removal and Installation....only note is no need to drill out rivets around the exhaust pipe as I ended up just putting rivets back in.
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
I only put rivets back in around the pipe exit hole that just holds the metal ring in. all support structure rivet holes were rive nutted. sorry for the confusion.I'm missing something here... doesn't putting rivets back in defeat the purpose? I would think you want them all replaced so it becomes a bolt-only removal and Installation....
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Got it, perfectly clear now, thanks for the reply!I only put rivets back in around the pipe exit hole that just holds the metal ring in. all support structure rivet holes were rive nutted. sorry for the confusion.
- 11K
