- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Billet steering blocks for the Japan model Yamaha 4-stroke sleds (RX-1, RS Vector, Apex, FX Nytro)! In stock and available to ship!
2003-2005 RX-1/Warrior
RS Vector models
2006-2010 Apex Models
2011-2018 Apex Models
FX Nytro models
RS Vector models
FX Nytro models
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The sidewinder needs one of these for the top of steering stem. The plastic stock clamp will compress when torquing down the nuts and cause binding of the steering stem.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
ULMERIn stock and shipping!
I'm on your site and it says request a quote. Unable to add to cart?
thanks
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
I saw that too.ULMER
thanks
Snowbound98
- Mar 11, 2019
- Chicagoland
- 2015 SR Viper M-TX 153
I attempted to put this on my MTX but I had to make a 1/2” spacer block under it to keep it from binding. I’d be interested in a full piece block instead of the spacer. I’ll use this one on the XTX if the MTX unit will be available soon.
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
I wondered about this when looking at Ulmers design. The OFT racing design comes with the bottom spacer that's cut out to go over the nuts that hold the the bolts in place.View attachment 163405
Snowbound98
- Mar 11, 2019
- Chicagoland
Yeah, it fits over the nuts but isn’t tall enough for the MTX. Looks like it’ll fit the XTX though.I wondered about this when looking at Ulmers design. The OFT racing design comes with the bottom spacer that's cut out to go over the nuts that hold the the bolts in place.
- Apr 17, 2003
- Menno, SD
- Menno, SD
There should be no difference in a XTX vs MTX. What you bought is for a 2-stroke Arctic Cat model (doesn't require the spacer). All the 4-stroke sleds will require a spacer (and this is how we have made ours as well, so that it can be used on a 2-stroke or 4-stroke model). If you don't run a spacer the steering will hit the throttle bodies.
We are waiting for this spacer to be finish machined yet, once I have this piece I can begin shipping completed units.
DennyTuna
- Jan 28, 2017
- Ohio
There ya go, thanks for clearing that up Allen. My thought when looking at his pics was, there's no difference in the OEM piece to a trail sled, he's just missing the bottom spacer.
Snowbound98
- Mar 11, 2019
- Chicagoland
I have both sleds next to each other. The MTX has a taller block than the XTX. Next weekend when I’m back up there finishing up the sleds I’ll put it on the XTX and show you that it will fit. I held it up next to it but didn’t take a picture.There ya go, thanks for clearing that up Allen. My thought when looking at his pics was, there's no difference in the OEM piece to a trail sled, he's just missing the bottom spacer.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Have steering blocks in stock for the Japan made 4-strokes. I worked on and built a few for the Yamacat models, but have decided not to pursue that at this time.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Japanese model steering blocks in stock and shipping daily!!
- Apr 17, 2003
- Menno, SD
- Menno, SD
Japanese model steering blocks in stock.
- 7K
