RJROWE
- Dec 10, 2015
- cape st george
- 2008 ampex mtx with boondocker side mount tubo
Hey guys! Just wondering if anyone has anything they can tell me about installing the boon docker side mount turbo to my 08 apex mtx. The kit came off of a Rx1 and All I have is the turbo, header, turbo exhaust, intercooler, oil tank, fuel regulator or pump. Not sure what it is. So far I've bought a fuel controller, boost and a/f gauges.. Still a lot more to buy, new oil lines, water lines, oil filter adapter.. I know there's a lot more to buy, I've contacted boondocker and they've sent me the list of parts that come in the kit and I'm waiting on the installation DVD
I plan on running low boost. 5-7 psi so I shouldn't have to touch the fuel system right? Only hook up the fuel controller?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
the apex fuel system can handle 7lbs of boost no problem.
gouldsjett1
I installed a boondocker Turbo with the DVD they provided. You should have no problem figuring out what you need after watching the DVD, it is very detailed.the apex fuel system can handle 7lbs of boost no problem.
RJROWE
- Dec 10, 2015
- cape st george
Thanks guys!
RJROWE
- Dec 10, 2015
- cape st george
Yea I can't wait to see it, I'm going to study every detail, so when it comes time for the install it'll be that much easier!I installed a boondocker Turbo with the DVD they provided. You should have no problem figuring out what you need after watching the DVD, it is very detailed.
RJROWE
- Dec 10, 2015
- cape st george
Clutching?? Gearing?? I'm a Hard trail rider, I climb a few hills nothing crazy, looking for a good intermediate system?
gouldsjett1
Call Allen ulmer, he can set you up with a clutch kit that will work.Clutching?? Gearing?? I'm a Hard trail rider, I climb a few hills nothing crazy, looking for a good intermediate system?
thamax
0-s-o primary spring dalton low boost adjustable weights should around 75 grams at 7lbs
53/47 helix white spring 3-3 or 6-1 preload
ersky
- Feb 6, 2009
- ont canada
- 06 apex gt s/c (sold) 04 rx warrior apex converted 2 stage bender turbo. 12 venture gt (getting old)converted to 11 apex
building a custom apex
im looking for a oil tank from 1 of these kits any body know where I can get 1?
