gosnek
going to change oil in 05 venture rs, thinking about using amsoil 0w40. aany concerns?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
gosnek said:going to change oil in 05 venture rs, thinking about using amsoil 0w40. aany concerns?
It's a pretty popular oil, however I choose not to use as I always have consumption issues when I use Amsoil.
If you choose it, just keep a frequent eye on your oil level to make sure your not one as well who has consumption issues (some don't)
Gone Blue
- Oct 11, 2006
- Howell, Michigan
No issues, it will do just fine. You can use either 0W30 which your sled came with from the factory or 0W40 in your motor. G.B.
gcr3903
- Jan 31, 2007
- Phillips, WI. - U.S.A. -
- 2004 RX-1
I've used it for 4 years with no issues.
kyzer
I use it and have no issues with it....
XTC500
Sorry for somewhat hijacking your thread but this is a related question. The manual recommends changing the filter every 20,000km or 12,000mile. Does anyone really follow this recommendation or do they change their filter ever time they change the oil?
jamesc
personally i always change filters when changing oil. you can get a quality filter (manufactured by champion) from walmart (yes i hate supporting them) for $3. iirc the number is ST6607
Ronder
If my new Vector still has 000 miles on it at the end of the season, do I have to change the oil and filter?
Paraclete
Good question
What if you only put 500 on in a season would you still change it?
Vectornut
Yes and Yes.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Oil can turn acidic and that is why it is suggested to change your oil annually regardless of milage.
Even Amsoil, who has a 25,000 mile drain interval suggests it is changed annually even if those miles aren't met.
Good article here and the reason I use Mobil-1 0W-40 European formula as it has more ZDDP
http://www.off-road-outdoors.com/Oil-breakdown.html
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
Same comments as Irv's posting.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Ron,
You should/could have miles on running around the lake! Anyways...you'lll get miles on.
111
111
