Kirkdking
Fooling around with some clutching I got super tip weights in the primary and a apex helix on the secondary set on 3 and 3 with stock spring.
Looking at changing the spring mabey or the twist on it some said that a green arctic cat spring works good or do any one have an idea what would work a bit better maker more twist???
I got no real bottom end loads of mid and top end but no bottom from a dead stop..
On the super tips I got a weight on the heel and on the tip, had to put the one on the tip cuz I was over revving cuz I got 8 tooth drivers installed. Still running 21 39 gears.
