21GT
I Have a set of the BOP tunnel coolant hose protectors in I was going to install this week on my 21. My question is before I do are they still necessary on the 21 sleds?
Joseph Levandoski
- Oct 19, 2016
- Ellington, CT
- 2019 Yamaha Sidewinder X-TX LE 141
I don't believe there were any changes to how those hoses were routed through the front of the tunnel - yes, I'd still put them on.I Have a set of the BOP tunnel coolant hose protectors in I was going to install this week on my 21. My question is before I do are they still necessary on the 21 sleds?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Supposedly the hoses in tunnel were improved to resist punctures, but they are still exposed. I still recommend them as they are cheap insurance.
NYTurbo
If your going to run tunnel protectors go full length STMs and they protect hose
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Going to pull my skid tomorrow on the 22 and see what they look like.. Ill post a picI don't believe there were any changes to how those hoses were routed through the front of the tunnel - yes, I'd still put them on.
21GT
Alright cool thank youGoing to pull my skid tomorrow on the 22 and see what they look like.. Ill post a pic
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
This is why you put hose protectors on. High speed ice trail cruising at -30 ish . Had already cleaned the one side off when i Realized should take a pic
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Pics of 2022 hoses. Looks different then my 17 for sure. The left side has virtually no hose exposed as it’s mostly metal now. The right side is got a lot of protection from the wide hose clamps. Not sure what the cloth material is or if there is rubber hose underneath? Felt very robust the right side. Steel reinforced hose? My guess
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
21GT
So will the BOP protectors fit on the hoses still?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I don’t know. I did not run them on my 17. Nor on this one. Just wanted to show what’s on the 2022. Travis will chime in on that one I’m guessing.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
I installed on my 21 srx with no issues which was first year for the braided hose.So will the BOP protectors fit on the hoses still?
21GT
Ok I'm going to install them then. for the extra peace of mind. Thank youI installed on my 21 srx with no issues which was first year for the braided hose.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I am in the process of removing my BOP hose protectors and installing STM tunnel protectors since I am running studs.
If your going to stud better off to buy full length tunnel protectors.
