Black 1000
Ya ok me want one. Let me know how and when and I'm in.
sleddheadd
made a payment via pay pal this morning. i will send you a quick pm now!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Looks like our paypal is back up and working. srxspec@gwtc.net for those of you in Canada please send the funds in US dollars or your payment will be denied. Thanks!!
sleddheadd
recieved everything!!! thanks alot!!!
Yummy
Here are some pictures on Ulmer Temperature gauge.
Can someone tell me What is the temperature range of the Apex. So far, I know the side radiator start at 196F.
- Apr 17, 2003
- Menno, SD
- Menno, SD
On moderate trails I generally see 180*F water temps on average.
sleddheadd
allen,
do you have any suggestions for mounting this digital guage on an rx series? i finally looked close at everything last night and found i really didn't have enough wire to get the thing mounted next to my speedo on my warrior. where else might be a good place for this or any other suggestoins? thanks for your help!
- Apr 17, 2003
- Menno, SD
- Menno, SD
On the RX/RS style sleds I usually use the velcro and put it on the handlebar pad, but have also extended the wires before and put it on the dash as well.
sleddheadd
ya' know i did think about that but i wasn't sure if it would stay on there in the cold temps...... that velcro will stick that good , huh? ...... we will give it a shot then! thanks!
Yummy
First test of my digital water temp.
Slow trail (35-50): 172-176*F
Medium (50-65): 180-186*F
Fast (65-90): 188-196*F at this point the side fan goes on then water temp. go down to 182 before going back up.
Very Fast (above 90): the highest I saw was 202*F.
Then we did 4 miles on ice road with NO snow, the temp. when up.....At 213, the high temp. light when ON. After, the temp when up to 215..stay there a few minutes then when up to 216-217. All this was at 50mph.
I'm very happy with this gauge. Now I know exactly what going on with water temperature under the hood.
Next I will be installing a rear exchanger...if I can find one, seems everyone is out of stock for the next 2-3 weeks.
Seeya!
Seeya!
lakercr
Tech Advisor
sleddheadd said:allen,
Allen also has BPE gauge pods that you might want to consider for mounting.
donbarb
Temp guages
Gary and Allen, just a report on the 2 guages I bought from you in the fall. Have got about 2500 kms on these units so far, and they work perfectly. Time and Temp are right on. Been out in -35 and +5 degree weather, and no complaints. Just 1 question about Yamaha temp. Would it not be benificial to run the engines a little hotter thermostat, or is this Yamaha's safety margin? Thanks for any info...Regards....Don
RacerDave
Did this group buy ever happen? If not and it comes up again I'd be interested in both parts. rr
- Apr 17, 2003
- Menno, SD
- Menno, SD
I've sold I believe 60 of these this season. I still have 1 left in stock.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Just an update to everyone on this. I recently had sleds sitting outside in 90*F+ temps with the water temp gauge sitting in direct sunlight and it wasn't good (LCD went black and have yet to get it to work)! So please, if you take your sleds out in the summer throw a rag or towel over the gauge so the sun isn't beating directly down on it (just a rag or towel over it so the sun isn't beating directly on it will be enough to keep it from getting damaged)!
